Mine is having the same issue. I sent the dump in this morning. Same dump file name as above. Running 1.14.7 x64. I sent it to support, didn't realize there was another email address. My tgz file was ~1.6MB.SSutherland1002 wrote: ↑Sun Jan 26, 2020 12:15 amYours has the same last 4 characters as mine! Wonder if that means ours came from the same original source and they're having a problem decrypting that one
Zombieland 4K UHD AACS 2.1
Re: Zombieland 4K UHD AACS 2.1
Any update or progress on Zombineland 4K AACS2.1?
Must be a unique variant as I’m able to rip my North American copy no problems. I’m sure mike is on the case.djj82 wrote:Any update or progress on Zombineland 4K AACS2.1?
Still not working for me either. I just updated to 1.15 and also still doesn't work. Mine was also a Best Buy Black Friday special. And by special, I mean useless.
Hello. I'm having the same issue. I bought mine from Walmart a few weeks ago. 4K disc is the one that is giving the error. I'm emailing the dump file now.mike admin wrote: ↑Mon Jan 13, 2020 12:45 pmApparently there are some "different" Zombieland discs out there. What kind of disc do you have? Anything special about it? Where did you get it from?djj82 wrote: ↑Sat Jan 11, 2020 1:52 amHad the same issue again today 1/10. I thought AACS2.1 was supported in the latest MakeMKV and Zombieland was already a supported title. Sent in the dump, lets see what happens!olevelo wrote: ↑Tue Dec 24, 2019 7:16 pmDoes anyone else have a version of Zombieland that won't decrypt? I have the latest version of MakeMKV but it gives me a dump and says "The volume key is unknown for this disc - video can't be decrypted". I sent the dump in 10 days ago but haven't heard anything...in the past the discs were usually added within a couple days with no response. Just curious if anyone else has seen this issue.
Any updates from anyone on this? I just sent another dump in, as I never got a reply from the one I sent months ago. Is there any other program that can rip this disc? I'd really like to watch it. :/
Just updated to 1.15.1, but still no dice.
Does MakeMKV say it is downloading the latest HK?
For UHD enabled drives (AU/NZ/SG) & DIY Single Drive Flasher (WW): https://www.uhdenableddrives.com
Yeah, and I know it's updated because I submitted a dump file for Midway a couple days ago and tried again today and Midway worked but Zombieland still doesn't.MartyMcNuts wrote: ↑Sat May 02, 2020 1:59 amDoes MakeMKV say it is downloading the latest HK?
Still nothing. And I can't get a reply from anyone via email either.
Am I right to say that this issue is limited to the International UHD and not the one released in the Americas?
I ripped Zombieland Double Tap yesterday and was thinking of ripping the first part today.
Sent from my Moto G (5S) Plus using Tapatalk
I ripped both Zombieland & Zombieland: Double Tap (Australian UHD versions) months ago. Had zero issues with either.
Ok mate. Going to give Zombieland 1 (UK) a go soon.
Zombieland UK ripping in progress. So working fine.
Using LibreDrive mode (v05 id=4FBA32AEC678)
File 00001.mpls was added as title #0
File 00102.mpls was added as title #1
Title 00244.mpls is equal to title 00001.mpls and was skipped
Title 00245.mpls is equal to title 00001.mpls and was skipped
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00337.m2ts was added as title #2
File 00338.m2ts was added as title #3
File 00339.m2ts was added as title #4
File 00340.m2ts was added as title #5
Saving 1 titles into directory D:/MakeMKV/Zombieland1
