ImCoKeMaN wrote: ↑Sun May 17, 2020 4:56 pm
SamuriHL wrote: ↑Sun May 17, 2020 3:41 pm
Now you ASUS owners have a tough decision to make.
Because if you flash the NS60 MK firmware to your drive, you no longer are impacted by the sleep bug and UHD ripping should work at rip lock speeds. Decisions decisions because you do lose UHD friendly compatibility with other software, but, the speed gains are tremendous with LibreDrive.
Other software? um, if there is a clean upgrade from the asus mk firmware to something that rip everything including UHD with unlimited read speed I don't see the downside. I must have missed the threads about this particular cross flash.
Some other software can only use UHD Friendly drives and not official ones. If you use other software, then flashing the NS60 MK firmware would not be prudent.
For most of the 1959 chipset drives, afaik, they can be cross flashed with the NS60 official firmware. This doesn't turn them into a REAL official drive, but, it does kill the sleep bug problem. And now with LibreDrive rip lock removed, it would be faster than any other firmware out there. I know for sure the
BW-
16D1HT can be flashed with the NS60. I have one.
I keep that on 3.10 MK to use with AnyDVD (that other software I was referring to) and I keep my NS60 on 1.00 for use with MakeMKV.
