Special features of 2009 Star Trek film won't rip
Muzer
Post by Muzer » Sun May 08, 2011 12:22 pm
Due to the CellWalk algorithm not working, and CellTrim not working on short titles, the special features on the Star Trek 2009 film PAL Region 2 DVD aren't available. This is the output for the "Open disc" thing:
Drive BD-ROM ATAPI iHOS104 WL0B has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-8 were removed from title start
Cells 40-40 were removed from title end
Title #19 was added (31 cell(s), 2:00:58)
CellTrim algorithm failed since title has only 2 chapters
Title #67 (0:18:51) was skipped due to navigation error
Title #68 (0:06:14) was skipped due to navigation error
CellTrim algorithm failed since title has only 3 chapters
Title #91 (0:04:30) was skipped due to navigation error
Title #97 was added (10 cell(s), 0:00:41)
Is there anything that can be done about this? The same thing happens on all my drives (including ones that don't have the RPC error listed above), with the same output (minus the RPC error).
Muzer
Re: Special features of 2009 Star Trek film won't rip
Post by Muzer » Sun May 08, 2011 1:09 pm
Disc name: STAR_TREK_XI_EU
Log and IFO files attached
MakeMKV_log.txt
(7.63 KiB) Downloaded 341 times
ifofiles.tar.bz2
(108.68 KiB) Downloaded 253 times
Muzer
Post by Muzer » Tue May 31, 2011 11:16 am
Any updates? It still doesn't work in 1.6.10.
Perry
Post by Perry » Tue Jan 01, 2019 9:13 pm
I have been a little slow in digitalizing my DVD films, but this one I have solved now. Open manually and use the following string to make it work; "20:@10-@40"
I hope it works for you too, or that you already solved the problem.
