www.makemkv.com
MakeMKV support forum
It is currently Tue Jul 17, 2018 7:57 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 31 posts ]  Go to page 1, 2, 3  Next
Author Message
PostPosted: Thu Jun 02, 2016 6:44 pm
Offline
I carefully followed the steps for linux but there must be something I do not understand. Would someone kindly detail the steps for a "newbie"?
Top
 Profile
PostPosted: Fri Jun 03, 2016 2:22 pm
Offline
What part are you struggling with it? Is there a certain step that is giving you issues?
Also, it's best to run MakeMKV on a debian-based flavor of Linux. What OS are you running?
Top
 Profile
PostPosted: Fri Jun 03, 2016 2:25 pm
Offline
To Mike/Admin...this should most likely be moved to the MakeMKV for Linux sub forum...
Top
 Profile
PostPosted: Wed Jun 08, 2016 7:19 pm
Offline
The message body won't allow me to use it.
I am using Mint 17,3 - Rosa. I downloaded both files and extracted them and opened,them one at a time then i put the codes in the terminal. Nothing seemed to be happening so I read the rest
of the instructions and found I needed to put another downloaded file and installed it. Still nothing . I suspect my problem is with the two MKV files. How should I deal with them?
Top
 Profile
PostPosted: Wed Jun 08, 2016 7:52 pm
Offline
In your home folder, create a Downloads directory if it doesn't already exist.
Then from the command line/terminal begin running the following commands 1 by 1...
Code:
cd ~/Downloads
wget http://www.makemkv.com/download/makemkv-bin-1.9.10.tar.gz
wget http://www.makemkv.com/download/makemkv-oss-1.9.10.tar.gz
We now need to unpack the tarballs...
Code:
sudo tar -xvzf makemkv-bin-1.9.10.tar.gz
sudo tar -xvzf makemkv-oss-1.9.10.tar.gz
Now we need to install all dependencies. Do these each 1 by 1 as they may be failing someplace....
Code:
sudo apt install build-essential
sudo apt install pkg-config
sudo apt install libc6-dev
sudo apt install libssl-dev
sudo apt install libexpat1-dev
sudo apt install libavcodec-dev
sudo apt install libgl1-mesa-dev
sudo apt install libqt4-dev
Time to start installing; move into the oss-directory:
Code:
cd ~/Downloads/makemkv-oss-1.9.10
sudo ./configure
sudo make
sudo make install
...continue on with installing...move into the bin-directory
Code:
cd ~/Downloads/makemkv-bin-1.9.10
sudo make
You'll now be prompted to read T&C/EULA type stuff...so get to the bottom of the doc. Upper G (shift-g) should take you there. Press q as instructed. Type yes as instructed if you agree. Then onto the following
Code:
sudo make install
cd
At this point you should be back in your home directory. By typing makemkv in the terminal, the application should start.
Please keep in mind that if you're looking to extract Dolby TrueHD and DTS-HD Master Audio formats that are relatively standard with Blu-ray, you'll have more complex instructions that will need to be followed. HOWEVER, you still WILL have either the Dolby Digital or DTS Digital files available.
Top
 Profile
PostPosted: Sat Jun 11, 2016 5:31 pm
Offline
Code:
cd ~/Downloads
Code:
Code:
Code:
sudo ./configure
sudo make
sudo make install
Code:
sudo make
Code:
sudo make install
cd
Nice. but why?
sudo ./configure
sudo make
Why they are need sudo user permission? I have try to Kubuntu and they don't.
I use only Debian and only "super user staff" is install "make install" "su" in Debian.
There is very simple tutorial here:
viewtopic.php?f=3&t=224
Just follow it and you are just fine.
_________________
OS: Debian 9 (Stretch) 64-bit, KDE
ODD: TSSTcorp. CDDVDW SH-224DB
Top
 Profile
PostPosted: Sat Jun 11, 2016 6:59 pm
Offline
Except the OP said he followed that walkthrough and didn't understand it. His response on what he was struggling with was fairly vague as well, and based upon how he was describing most of what he was doing it sounded like he was handling this both via UI and CLI, which can get messy.
Hence why I gave him the even more granular step-by-step breakdown. You'll also notice that the walkthrough I provided is exactly what's already described in that post, just more detailed and leaves less ambiguity.
16442496 wrote:
Nice. but why?
sudo ./configure
sudo make
I have no idea how this user's permissions are set up, nor what is causing issues. Using sudo won't hurt anything here and more than anything just ensures everything gets installed. Across various Debian flavors, I have issues not using sudo for ./configure or make, so adding this seems to work.
Debian handles the super user privileges differently than Ubuntu or Linux Mint (what OP is using). Debian by default requires full root access (and password), whereas Ubuntu/Mint do not. Thus using sudo will work just fine for OP.
Top
 Profile
PostPosted: Tue Jun 14, 2016 8:29 pm
Offline
e="16442496"]
Nice. but why?
sudo ./configure
sudo make
Debian handles the super user privileges differently than Ubuntu or Linux Mint (what OP is using). Debian by default requires full root access (and password), whereas Ubuntu/Mint do not. Thus using sudo will work just fine for OP.[/quote]
I looked up Debian and found so many packages I became confused again. I never knew that Debian was an OS. I would like to install it but don't know which to install nor how to do it. Would you kindly wake me up?
Top
 Profile
PostPosted: Tue Jun 21, 2016 3:25 pm
Offline
I am using Mint 17.3, I explained that I was a "newbie", I had never used the terminal before and I asked for more specific instructions. I was not told that I had to hit "enter" nor when to use it.
Here is where I am now:_PATH=/tmp/ffmpeg/lib/pkgconfig ./configurePKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig ./configuresudo make install
bash: ./configurePKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig: No such file or directory
jeff@jeff-A780L3B ~ $ rm -rf /tmp/ffmpeg
jeff@jeff-A780L3B ~ $ sudo apt-get install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev./configuremakesudo make install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libqt4-dev-bin' for regex 'libqt4-dev.'
E: Release 'configuremakesudo' for 'libqt4-dev-bin' was not found
E: Unable to locate package install
Please see above.
I appreciate the help you have given me and the work you had to do for me but when should i hit "enter"? Is it after each line of code or after each grouping of code.
Top
 Profile
PostPosted: Tue Jun 21, 2016 3:47 pm
Offline
Hit enter after each line.
If you're not very familiar with the command line interface (CLI), I recommend that you read this document as it will help you find your way around more: https://help.ubuntu.com/community/UsingTheTerminal
Also, it appears that you're following some of the commands from the optional section on the install instructions page. Are you wanting what's included in that? If so, it's a MUCH more convoluted mess and you won't be able to follow them directly as some of the packages don't seem to install well. ffmpeg, while powerful, is a PAIN to get configured, even for skilled Linux users.
Top
 Profile
PostPosted: Tue Jun 28, 2016 11:14 am
Offline
The commands were working properly until I got to the password and it was not accepted - a number of times. Once I get that accepted I should be fine. I was unable to log in since you last post but I finally got that straightened out. Thanks for your help.
Top
 Profile
PostPosted: Thu Jun 30, 2016 2:32 pm
Offline
Okay, thank you. I am using Mint 17.3 Rosa. What version should I be using?
Top
 Profile
PostPosted: Thu Jun 30, 2016 4:01 pm
Offline
Which version of what? OS?
Top
 Profile
PostPosted: Thu Jun 30, 2016 5:07 pm
Offline
You said you only use ?debian? I think. Is there a debian version of mint?
I triedd installing the debian OS and as I recall I had som3e difficulty with it, possibly because it was very different from what I am used to.
Top
 Profile
PostPosted: Fri Jul 01, 2016 3:54 pm
Offline
Mint is a Debian- (and Ubuntu-) based OS. I was asking this initially because MakeMKV for Linux is really only intended
for Debian-based flavors of Linux.
MakeMKV should generally work without issue on Mint. I personally use Ubuntu Server for MakeMKV (not Ubuntu with a UI), but the install should generally be the same.
Let me install a Linux Mint VM and install MakeMKV so I can perhaps clear up my instructions which are more specifically for Ubuntu.
I'll try and post an update later today.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 6 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
